When using running snaps, the command automatically advances to the z field upon making a selection. Using the control (right click) snaps, the command stands on the coordinate field pausing for enter/tab verification. In fast moving productive entry of layout line ticks on various different design features, namely underground utility structures, this conditions trips up the user (me anyway) quite frequently. Is it possible to coerce the command to automatically advance to the z field while using the control snaps, similar to the coordinate selection behavior of using the running snaps? If not, is it possible to “enhance” the command so that it will?
Bump for attention on this request.
We are about to start work on improvements to this tool - will add you to Beta so you can make sure you get what you need here
