QA Road Lines Command
  QA Road Lines
  • The QA Road Lines command is part of the RPS Modeling Toolbox
  • The command is located on the Reports macros menu ribbon
  • The command is located in the Reports menu group
Command Description
Creates a profile in the alignment profile view for a corridor that shows the delta elevation between a selected 3D line and the selected corridor material surface layer e.g. Finished Grade. Used as a check between survey data and a selected corridor model or to determine the variance of cross slope along an alignment based on survey information.
Command Training Video
The following video shows how to utilize the QA Road Lines command
Command Updates
June 1 2023 - the command was renamed to QA Road Lines from Elev Delta to Corridor with the 5.90 RPS Command Library update. The command was also moved to the reports menu ribbon along with all of the drafting, reporting and export tools. Functionally the command remains the same.
The QA Road Lines command dialog looks as follows
Lines:
Select the line that you wish to compare to the corridor model (material layer of a corridor model). Each line selected will generate a separate difference profile. The difference profiles are added to the alignment of the selected corridor as additional ground profiles. You will find them at or around 0 elevation in the profile view of the alignment.
Corridor:
Select the Corridor model to which you want to compare the selected lines.
Material Layer:
Select the Material Layer for the selected corridor to which you want to compare the lines.
Vertical Offset:
Input a Vertical Offset to the Corridor Model / Material Layer elevation if you wish to compute e.g. to a subgrade adjusted elevation in the absence of material layers in the corridor model itself
Command Tips
Header Commands
  • Help - this document access
  • RPS Settings
  • Takeoff Lines
  • Smart Edit
  • Adjust Linestring Elevation
  • Create Alignment
  • Create Corridor
  • New Profile View
  • QA Notebook
  • QA Lines
  • QA Points
Compute
When you tap Compute, the “Delta Profile” between the selected lines and the corridor model will be computed and assigned to the corridor alignment as an additional Profile. The command closes on completion.
Close
Use Case Videos
The following videos show the use of the QA Road Lines command in a work process context
If you would like to provide feedback on the use of the QA Road Lines command or to request enhancements or improvements to the command please click Reply below
