I am trying to create a Mass Ex surface, where a fixed slope will tie into the original surface at different elevations. In the screenshot below, I need the white lines to terminate when they meet the same elevation as the green lines.
Just a surface tie at slope?
Thats what I was looking for. Thank you
Hey Ryne,
You could look at our slope designer command if you need more flexibility in the tie slope calculation. Here is a link to the help guide which has an explanation video.
You can also look at using Sideslope in the standard TBC tool kit but you may run into issues around your right angle corners.
