Project Files Command
  Project Files
Command Licensing and Default Menu Location(s)
  • The Project Files command is included in all Toolboxes
  • The command is located on the Smart Suite and RPS Support menu ribbons
  • The command is located in the Files menu group on Smart Suite menu
  • The command is located in the Core menu group on RPS Support menu
Command Description
The Project Files command opens the Windows File Explorer at your currently active Project File’s folder location, so that you can quickly access data that has been imported, generated or reported from the current project.
Command History
Version 1 released in Dec 2023
Video Demonstration
The following video shows how to utilize the Project Files command
The Project Files Command has no user interface. When you click the icon or run the command it simply fires up Windows File Explorer at your current projects folder location.
If you would like to provide feedback on the use of the Project Files command or to request enhancements or improvements to the command please click Reply below
