Hello. I am setting up some point label styles and I cant seem to figure out how to utilize a label symbol when labeling the point. I have symbol size and type set in the style, but when I go to label it does not seem to display. Are there any tricks here, or something I am not aware of to make the symbol display as part of the label?
Thanks!
When you were done setting everything the way you wanted, did you hit Add at the bottom of the screen?
That should have changed the symbol in the preview window to what you selected, once that is complete the label should show correctly.
That’s it, I was thinking that the symbol was already part of it.
Thank You!
I am still learning how to drive this thing.
Much Appreciated
Yes sir. It’s an easy one to miss.
