Is there any way to choose which node is getting labeled in cross sections? I want to auto generate elevations to make quick analysis easier but I get an elevation at ever node. The surface is flat (level) so I really only need one at the beginning middle or end.
222510 - Cliffs at Wildwood.pdf (798.1 KB)@Ruth_Staiano helped me out with this. If you name the breakline, you can filter by this so at most I have 2 labels now which is more reasonable.
The filters is the way to go
If you prefix the names of features that you want to label with L then you can put in L* here and it will only label those with an L at the start of the name for example - sounds like Ruth got it dialed in for you
Thanks Ruth as always - you keep us all in line - nice work!
