Is anyone else having issue offset line command in sheet view, command only seems to work on plan view
Had the same issue about 3 weeks ago. It has been submitted to TBC technical support and they are working on it.
Nudge will work in Sheet view but only for small offsets - you would have to make a copy of the line first
Multi offset line doesn’t work in Sheet View
You found a Bug!
