In this video we show you how to model the inside of a Spoon Drain in 3D using Multi Offset Line Command. You can also model the outside surface of the spoon drain as well if needed - subject of a follow on video
This second video shows how to model the Outside Diameter of the same spoon drain pipe.
And with a slightly modified template you get this with the top edges closed out
