Would It be possible to enhance this command, where you could have a batch of multiple surfaces overlapping,
- Each surface would be given a hierarchy, to allow the correct merge order?
- Also, each surface would be given the type of merge option
A preview window of each surface boundary would be helpful, to determine the merge type incase of any overlap in the surveys
I concur with this. This would be great for trench surfaces.
That would help out a lot I come across this problem all the time.
would greatly cut down on file size and save time.
What program is that from? Carlson has something very similar, but not always the easiest to use. TBC I have have to offset boundaries, trim and buffer before combining.
