Menu Manager
- The Menu Manager command is part of the RPS Core Tools Toolbox
- The command is located in the System Management group
Command Description
Provides a simple and easy way to switch menu configurations from a light theme to a dark theme. The dark theme is easier on the eyes for those long days of clicking and pointing.
Video Demonstration
The following video shows how to utilize the Menu Manager command
Latest Updates
June 2023
- Added Header Commands for quick access to all menu, toolbar and command shortcut management functions of TBC.
- Added the ability to Toggle On / Off the Unlicensed Commands Menu
- Addressed an issue with Dark Mode not being retained in certain situations
The Menu Manager command dialog looks as follows
Color scheme:
Select the color scheme that you require for the menus. The Default scheme is the Light Grey scheme of Trimble Business Center, the Dark scheme is the medium grey color scheme that was used in the Traditional (Business Center - HCE) color scheme. In both cases we utilize the same icons for the commands.
If you ever find any RPS command icons that are not showing the correct icons you can refresh the icons by clicking the Refresh Icons button and then toggling between the Default and Dark modes.
Remove RPS menus button:
Click here if you wish to remove the RPS Macro menu ribbons from your setup. This will remove the R-Data Prep, R-Modeling and R-Tool Shed menu ribbons.
Reset RPS menus button:
Click here if you wish to restore the RPS Macro menu ribbons to your setup. This will create the R-Data Prep, R-Modeling and R-Tool Shed menu ribbons and place all of the TMLs on the correct menus and in the correct locations (menu groups etc.).
Refresh icons button:
Click here if you need to refresh the menu ribbon icons. In some situations we have found that the icons displayed are incorrect after an update, you can refresh the icons using this function.
Command Tips
The command Tips pane shows you how to access Help for the command (this web page).
Header Commands:
- RPS Help
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- Set Ribbon Tabs
- Customize Ribbon
- Toolbar Manager
- Shortcut Manager
OK
Cancel
Closes the command without further execution
If you would like to provide feedback on the use of the Menu Manager command or to request enhancements or improvements to the command please click Reply below.
