Mass Haul Display
How do you change mass haul zone info and haul roads color, lineweight and text style to make printable and presentable?
A lot of the mass haul parts are hard coded and the objects may not be fully editable - I will need to look at that a bit myself to see what is possible.
If TBC won’t let you change properties, you may be able to export those elementsbto DWG and reimpory the DWG and then edit those imported objects to get the look that you need.
I have not tried exporting those elements so I cannot say that does or doesn’t work - I would have to try it myself.
