Has anyone got a workflow for modelling roads with large box culverts.
I’m looking for a clean way to
- use single side slope command that will interface the OG but also tie to back of headwall surface when culvert is present. ( i have alot of condition commands to build terracing through this area, relying on side slope height)
- x sectional fill area to be exclude where culvert surface is present.
thanks guys
              Possibly create 3D lines using the Side Slope tool to get those back strap and add those lines to the Corridor.  This maybe a combo of different commands.
              Hi Peter,
I know this might be a long shot, but I wanted to throw an idea your way. Could you model the culvert itself and use the trench excavation feature to define where the roadway tie data should conform? Essentially, this would allow you to use utility commands to create both the necessary “void” for embankment deductions (within the box and concrete) and a surface that interacts with your design.
In my section below, the red surface represents what you’d need your culvert surface to be, essentially the point where your roadway slope would tie into the culvert surface. Would this approach work for your case? Let me know your thoughts!
