I just found out that you can use the label manager to automatically label pipe runs and nodes. The only downside is there is some fields missing. Is there a way to call on these like we can with smart text?
If not, can we put pressure on the TBC team because this would save a ton of time when labeling data for design and QA/QCing. #automation
Fields missing:
- ** lines/run**
- name
- material
- start elevation
- end elevation
Options missing
position of label
- beginning - label invert
- middle
- end - label invert
** nodes/points**
- rim elevation
- material
- height
Math equations as well are necessary.
The other advantage is this is linked to the nodes and pipes so if something is moved, the label also moves.
