Is it possible to Add Approx. Volume Delta to Earthworks Report?
Is there a convenient way to add the Approximate volume delta per .1’ to an earthworks report?
123
By depth just shows me the volume per foot between the two surfaces, not how much volume change there is by adjusting one of two surfaces closer or further apart.
Is this what you need?
Yep that looks like exactly what i need.
This is from the Custom Takeoff Report on the Takeoff tab. It spits out a Word doc that I clean up and export as pdf. Perhaps the new RPS reporting tool will show this as well?
Gotcha, you must have edited your post with the picture to show exactly what you wanted.
I realized after your reply my file didn’t upload initially, thank you :slight_smile:
These values are all in the Smart Takeoff Reports Grady.
