Import Pile QA Data Command
- The Import Pile QA Data command is part of the RPS Tool Shed Toolbox
- The command is located in the Piling menu group
Command Description
Provides the ability to import machine generated as built pile information and surveyed points QA information for As Built Piles to create As Built Piles And Pile QA Checks for Solar Farm piling projects.
*** ## Command Interface Description
The Import Pile QA command dialog looks as follows
Place picture of command dialog here
Dialog Input 1:
Describe Dialog input 1 here
Dialog Input 2:
Apply
When you tap apply, XXXXX and the command will ready itself for another selection set and repeat process execution. If you do not want to make a second selection and repeat the process tap Close to finish the process.
OK
Close
Cancel
Video Demonstration
The following video shows how to utilize the Import Pile QA Data command
Use Case Videos
The following videos show the use of the Import Pile QA Data command in a work process context
If you would like to provide feedback on the use of the Import Pile QA Data command or to request enhancements or improvements to the command please Click Reply below
