How To Convert MText Point Lists Into Points
In the video below we show you how you can take a set of coordinate values imported from a CAD file as MText objects and convert them into 3D points. The process involves copying the MText data to the clipboard and passting it into Excel, and then use Text To Columns in Excel to split the data into fields, save the CSV file and then import the CSV file back into TBC. If you have a lot of data points this can be a huge timesaver
