I had a chat with a user this morning and he was frustrated with the TBC Geometry Report - he said the report is exactly the data he needed, it was just one line per work sheet in Excel - so for 100 pipes he had 100 Worksheets to look through - why could it not generate all the data in one Sheet?
In Excel - use Print Entire Workbook and Print to a PDF File - that will print everything into one large PDF file that you can then read through rather than having to change Work Sheets each time you change line
