Fyi - Adjust LS Elevation
Command leaves behind itty bitty FlagEggs. Some hatch, some don’t. But they are there, still in the surface. Ready to get you on the third revision.
Usually single point +/- linestrings at the Loc 1 and Loc 2 coordinates.
I will get that checked and fixed - I reproduced the issue
FYI - The command continues to exhibit similar behavior in command ver. 1.20.
Peter did look at this and spent actually days on it - he never did work out how to stop those zero length elements from happening. However in the latest version to be released we made some changes that may address the issue - I need to look at it again to see if it did solve this one also.
