Filter by Alignment
- The Filter by Alignment command is part of the RPS Data Prep Toolbox.
- The command is located in the Select menu group.
Provides the ability to filter a selection of objects in relation to a selected reference line or alignment. The user can define parallel, perpendicular, or skew-angle criteria to rapidly find linear features or cross-section lines across surfaces. A useful tool to use with the Explode Surface or Explode IFC Shell commands.
COMMAND HISTORY
Last Updated: August 2, 2022
The command has been updated to allow selection of objects to filter from within the command so that multiple selections can be made while staying in the command.
The Filter by Alignment command dialog looks as follows:
Select objects:
Select the lines that you wish to make your filtered selection from. Use normal TBC selection methods (rectangle select, polygon select, click select/deselect etc.), or select Options for advanced selection methods like Select by Layer, Select by Polygon, Select by Elevation, etc.
The data that you will be filtering will typically have been generated using the Extract Surface Features or Explode Solids commands. The command allows you to find linework from a selection of objects that runs nearly parallel or perpendicular to a selected alignment or linestring.
Reference Geometry:
Select your reference alignment or line object. The line selected provides the direction for the filtering process. Along the reference line will be parallel to the selected reference geometry ± the maximum deflection angle. Across the reference geometry will be perpendicular to the selected reference geometry ± the maximum deflection angle.
Include “along” linework checkbox:
Checking this checkbox will select linework that runs approximately parallel to the selected reference geometry. You can enter a maximum deflection angle when this is checked to restrict lines that deviate by more than the maximum angle from being selected.
If you check the check box and enter a maximum deflection angle of e.g., 1 degree, you will only select lines that are longitudinal features that are nearly parallel to the alignment.
If you check this checkbox and enter a maximum deflection angle of e.g., 88 degrees, you will get all lines except those between 88 and 90 degrees to the alignment.
If you do not select this checkbox and enter a maximum deflection angle of e.g., 88 degrees, you will typically select only lines that are perpendicular to the alignment, i.e., cross-section lines.
APPLY BUTTON
Executes the command and converts the selection of filtered objects into the global selection, and pauses for an alternative selection or for you to use the properties pane or other commands to relayer the selected objects, join the selected objects (Join or Smart Join), delete the selected objects, change the name or color of the selected objects, etc.
OK BUTTON
Executes the command, selects the filtered objects and closes upon completion, leaving the selected objects in the global selection ready for the next process.
CLOSE BUTTON
The following video shows how to utilize the Filter by Alignment command:
The following videos show the use of the Filter by Alignment command in a workflow context:
If you would like to provide feedback on the use of the Filter by Alignment command or to request enhancements or improvements to the command, please click Reply below.
