Does anyone have any tricks for setting point elevations by adjacent linestring? Easy to do in cad, but cannot seem to figure it out in TBC. Use cases would be setting GL elevations on curb offset points, etc
Thanks!
Thanks!
Use mulri offset lines to create a line left and right of the line at 0% slope or 0 dz and have the template build you a surface - then elevate the points to the surface using Change Elevation command.
You can offset hundreds of lines in one pass and have the surface built automatically - place the lines on a temp layer that you can delete quickly afterwards
This is how I would do it
Thanks Alan, Ill give that workflow a shot.
