Edit Alignment as Spreadsheet
- The Edit Alignment as Spreadsheet command is part of the RPS Modeling Toolbox
- The command is located in the Corridor menu group
Command Description
Capture alignment details in a spreadsheet and then import it into Trimble Business Center using this command. Command also allows the user to open an imported or hand entered alignment in a spreadsheet for checking and analysis.
Command Training Video
The following video shows how to utilize the Edit Alignment as Spreadsheet command
Update Information
The Edit Alignment as Spreadsheet command dialog looks as follows
Alignment:
Select the Alignment that you wish to create or edit as a spreadsheet from the pull down list or select New on the list to create a New alignment. Note that if you intend to enter the alignment as a PI Based Alignment, then you need to check the Inscribe curves at PIs radio button on creating the alignment.
IN TBC you can enter alignments using segment geometry information or PI (Point of Intersection) information. The alignment stores the information in different ways depending on which method you pick. The two are not interchangeable, once you have picked the method, that is how the alignment needs to be entered.
If you make a data entry error or you enter a PI alignment for a Geometry type alignment or vice versa, you will see an error like this presented when you try to save the alignment.
Show station equation zone checkbox:
This will create a spreadsheet tab for Station Equation zones where you can enter Ahead and Back station values for the Station Equations for an alignment.
Spreadsheet Structure Notes
Within the Spreadsheet interface you have tabs for Horizontal and Vertical Alignment
Horizontal Alignment Data Structure
- Line 1 = POB Station e.g. 0.00 in cell A1
- Line 2 = POB coordinates N in Cell A2 and E in cell B2
- Lines 3+ = Line, Arc or Spiral segments
Line Segments
- Enter Bearing for Line in Cell A (? for Tangent or undefined)
- Enter Length for line in Cell B
Arc Segments
- Enter Bearing for Arc in Cell A (? for Tangent or undefined)
- Enter Length for Arc in Cell B
- Enter Radius for Arc in Cell C
Spiral Segments
- Enter Bearing for Spiral in Cell A (? for Tangent or undefined)
- Enter Length for Spiral in Cell B
- Blank in Cell C
- Enter Radius Start for Spiral in Cell D
- Enter Radius End for Spiral in Cell E
Here is an example of a simple horizontal alignment
Note the spreadsheet values will change if the alignment was keyed into TBC using the PI based method. In that case the same alignment would look as follows, this time with a Spiral - Arc - Spiral at the PI point
Vertical Alignment Data Structure
Here is the structure for the Data Entry of Vertical Alignments
To start entering a vertical alignment click the New button, enter a name and select Vertical Alignment followed by OK, This will create a new tab for the Vertical Alignment information. If for any reason you forget to enter a name for the vertical alignment, you can simply click on the tab name for the spreadsheet and enter a name there to update its name.
- Line 1 = POB Station e.g. 0.00 in cell A1 and Elevation in Cell B1
- Lines 2+ = Symmetrical Curve, Asymmetrical Curve, Vertical Arc or Grade Breaks
Symmetrical Curves
- VPI Station in Cell A
- Elevation in Cell B
- Curve Length in Cell C
Asymmetrical Curves
- Approach Curve Length in Cell C
- Departure Curve Length in Cell D
Vertical Arcs
- Radius in Cell E
Here is an example of a simple vertical alignment
Slope Table Data Structure
When you tap the New button you can elect to add a new Vertical Alignment or a New Slope Table for the alignment. The Slope Table is stored as a Shareable Slope Table on the alignment that you are editing. The format for the Slope Table is as follows
- Station in Cell A
- Slope in Cell B
- Vertical Curve Length in Cell C
You can see the result of the Slope table by looking at the Superelevation diagram for the alignment. You can enter any number of Slope Tables using this approach. If for any reason you forget to enter the name for the slope table, you can rename the tab in the spreadsheet editor to add a name after the fact.
Here is an example of a simple slope table entry
Example Master Format Data Sheet
Master Alignment Editor Format Sheet.xlsx (22.5 KB)
Command Tips
Header Commands
- Help - this document access
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- Create Alignment
- Create Horizontal Alignment Labels
- Create Corridors
- Create X-Lines
- Define Extra Stations
- New Profile View
OK
Cancel
Use Case Videos
The following videos show the use of the Edit Alignment as Spreadsheet command in a work process context
If you would like to provide feedback on the use of the Edit Alignment as Spreadsheet command or to request enhancements or improvements to the command please Click Here
