Has anybody come up with a way of drawing an ellipse in TBC? I can it can handle importing an ellipse from a cad file so it seems like it ought to be possible to draw one but I can’t seem to find a command for it.
i have not tried to create an ellipse in TBC and it appears one would have to hand calc the ellipse and create in bits. Cad created ellipse will import as such to TBC
any edit function will immediately turn it into a chorded line-string
Try drawing a circle and then make it a block. When you place the block you can Scale in X and Y separately which will allow you to create an Ellipse. You can rotate the block also if you want it other than vertical or horizontal .
