I accidentally used the wrong orientation when creating a sheet set, portrait instead of landscape. Is there a way to change this? With cross section and profile sheet sets it is a very obvious setting. I think i just have to create a new sheet set and copy everything over but this seems like a small oversight in the UI.
where it says orientation click to the left and a drop down menu will show up. I have redone set before until one day i click next to orientation and wow, you can change it from the properties.
Yeah, I just did a custom sheet and someone forgot to add some more option. It would be helpful to have the same option as the other sheets sets.
