Divide by Slope Distance
- The Divide by Slope Distance command is part of the RPS Data Prep Toolbox.
- The command is located in the Modify menu group.
Computes points along a selected 3D line using a table of variable slope distances as divisors. A useful tool for rapidly creating building grid layouts.
The Divide by Slope Distance command dialog looks as follows
Point Info:
The command will generate points at the slope distance or horizontal distance intervals that you specify in tabular form against a selected source line, e.g., a building grid line. If the line is horizontal, then slope distance = horizontal distance.
Start Point ID:
Enter the point number that you wish to use for the first point that is generated. Subsequent points will be numbered in sequence thereafter. You can use point IDs like A1 or B1 if you want different point numbering for an X-axis or Y-axis of a building for example.
Layer:
Select the layer on which you wish to place the created points. This control has been updated to use the RPS New Layer control, which allows you to create multiple layers and layer groups, assign Takeoff layer categorization takeoff boundary properties, and assign default site improvements for the objects to be created on the new layer.
In this case the data to be created is points, the points could be mapped to an object type like “Column” to count the number of columns for a takeoff. The Column site improvement would be defined using the MSI Manager in TBC and would be a count-type object. Each point created would then be a column count.
Define intervals
On clicking the Define intervals button, a spreadsheet-style editor will open. Enter the distances that you wish to create along the line. Note that the distances entered are the spacing between the points, not the distance from the origin of the line, i.e., values 0, 20, 60, 100 would create points at slope distances of 0, 20, 80, and 180 from the origin end of the reference line selected.
Reference Line:
Select the baseline (polyline, linestring, or alignment) along which you wish to compute the slope distances to create the division points. The points will be created on clicking a reference line. You can then click the Define intervals button again to change the divisors for a second line. You can change the values and select the same line again if required e.g., to change the point numbering system for the points being created.
APPLY BUTTON
When you tap Apply, the selected line will be divided by the slope distance tale values and the command will prepare itself for another selection set and another process execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following video shows how to utilize the Divide by Slope Distance command:
The command was updated on Jan 13 2021 - this video captures the changes:
The following videos show the use of the Divide by Slope Distance command in a workflow context:
If you would like to provide feedback on the use of the Divide by Slope Distance command or to request enhancements or improvements to the command, please click Reply below and post your comments.
