Cut fill map issue 5.4
Is anyone having problems with the cut fill map along a corridor surface?
I’m getting gaps in the cut fill map?
Gavin
If you can share the project I will take a look - I have been doing CF Maps all week on Corridors and haven’t seen any issues personally - check your edge length settings on the Isopach
Will do, but I think its more of a problem with the 12d surface
