Is there a way to extract the cut/fill line preduced when a cut/fill map is made? I would like to use it as a linestring to create cliping boundaries.
You can use the command “Contour at elevation” then choose the cut/fill map then choose elevation “0”, you can then explode that line and use it
          Or if you have RPS tools.
https://community.myrockpile.com/t/surface-intersection-linestring-command/306
thank you all, i actually did use the surface interscet command it worked well
