In the video below we show how to
- Create materials for a custom utility shape
- Create a custom utility shape drawing
- Create a Custom Utility Shape
- Create a Sanitary Sewer Network
- Create a Sanitary Sewer Run
- Create Sanitary Sewer Nodes
- Create a Sanitary Sewer Pipe using a Custom Utility Shape
- Create drilled shaft locations
- Create drilled shaft pile definition
- Create a pile plan
- Create Drilled Shaft piles on the points
- Visual checks in 3D model for clash between the custom utility and the drilled shafts
- How to draw custom shapes and show them as 3D solids e.g. Pile Caps
- How to copy e.g. Pile Caps from one pile to another
- How to extrude 3D shapes vertically
Custom Utility we are trying to create
The drilled shafts can also be a custom shape if required.
Video shows you how
