In the video below, you will learn how to create a composite surface model from several surface models that updates in line with changes to the source surface models. In the video you will see what happens when you add data that overlaps surfaces and how the composite model is created as a result.
When you modify or add data to one of the source surfaces, you will see how the composite surface dynamically updates in line with those changes to the source surfaces.
