I have created a template that I specifically use when I need to print sheets. I have inserted a company logo into that template and saved it as a new template so I can use it when needed. However, every time I hit “File”-“New” and pick the appropriate template the image is gone and I have these small little boxes in their place. Am I missing a step?
Before…
After I saved it as a template and then opened it again:
You will need to save the image in the drafting directory. This is happening due to that the project your opening does not have that image in its directory meaning in its project folder.
