This question comes up a lot, how do I create a quick slice drawing that cuts through 1 or more surfaces with high quality as a printout - a bit like Surface Slicer View but not pixelated in a PDF format.
The process is as follows
- Draw an alignment across the road where you want to cut the profiles
- Create Surface profiles through the surfaces that you want to slice along the alignment
- Open the profile view for the alignment
- Draw a rectangle to be used as a Dynaview Frame for the drawing around the profiles you created
- Create a Dynaview from the rectangle you drew and place it on a custom sheet in your Planset
- Add a Grid to the Dynaview for your grids for Stations and Elevations along the alignment
- Print Planset to generate a PDF output
Video shows you how
