I’m trying to use the create from CAD on a project. I have used the command on an earlier phase of the project and at first it gave me this same issue but after I cleaned my layering a bit it worked as I hoped it would. The issue is when I run the command it creates cross sections at the start and end of the job, but the middle of the job cross sections is missing. The command says that the correct number of cross sections are created I just cannot see them.
Its been awhile since i have used this command. from my experience, it was the text of the stations not being placed close to the cross section. try moving the text station.
Thanks for the advice, I tried that and moved the station labels as well thinking maybe that was the issue. Still have the same output so not sure what is tripping up the command.
