Please post responses to the questions here - interested in gauging your responses in relation to some work that we are doing currently. Any / All feedback welcome.
What settings do you use for Display in Plan or Display in 3D View for different types of surfaces i.e. Wireframe, Shading Method, Color, Slope Arrows etc. - i.e. if you could pick a set of defaults what would they be? How would they vary from Surface Type to Surface Type?
What Color do you use for
Existing / Original Surface
Finished Design Surface
Subgrade Surfaces
Overex Surfaces
Work In Progress Surfaces
As Built Surfaces
Topsoil Strip Surfaces
Demolition Surfaces
- Out of the Surface Classifications do you use any of the following ever
Mass Earthwork Prepped
Mass Earthwork Finished
Stockpile
Depression
I can see daily use of Original, Design, Work In Progress, As Built, Unclassified, Stockpile, Strata, Difference Model - would you agree that the others are rarely if ever used. If you do use them, when do you use them?
When you add Dates and Times to a Surface Model, what is truly necessary in the Time Field - Nearest Hour or Nearest Minute or Nearest Second - my gut tells me that 10:00am would be close enough, we could go to 10:25am but I don’t think Seconds is necessary - is that fair?
If you could Group Surfaces - what Groups would you want as defaults in every project. What variations could you see yourself using?
If you could decide by default that surfaces would be Rebuild By User vs Auto - when would you use Auto vs when would you use By User - how would you choose to set that up?
If Quick Contours could be built automatically as a part of Surface Creation, what defaults would you use for Major / Minor contours, how would you organize the layers that created for each set of Quick Contours (naming of layers, Grouping of Layers, bearing in mind that you will likely be creating many sets of contours for many surfaces so they cannot all end up on the same layer. What surfaces that you create would you want Quick Contours created for as an automatic function. Also remember that Contours get rebuilt each time you rebuild a surface, if your surfaces is set to Rebuild Auto, that will slow you down etc.
