Corridor Template - Copying and Pasting Instructions
In this example we show you how to
Copy and Paste Template Instructions within a Corridor Template
Copy and Past Template Instructions between Corridor Templates
Copy and Paste Template Instructions between Corridor Templates in different Projects
In the third example above we show you a strategy for how to create a library of custom templates that can be used on all of your projects - using 2 instances of TBC to have your master templates in one and the current project in the other, and being able to rapidly create corridors from master template data.
You will see that you can copy and paste all of the instruction types including multiple material layers, finished grade, subgrade, simple or complex sideslopes and superelevations if needed.
Mastering this approach can save a huge amount of time when building corridor models.
