We have made a corridor cut sheet for a new project but have an error where it reads the offsets backwards when the nodes are designed out to in and not in to out. For example, we have an existing outside travel lane collected but we need to design a median using the existing slopes so we have the corridor template set node to node from that outside travel lane to CL using that cross slope. When we ran the gradesheet, the sheet reads from CL: median BOC, median face of curb, median flow line, outside EP, median EP, outside curb… Is there a way to force it to read CL out like a gradesheet should be? The data for the columns are correct just not in the right order.
Can you share the project Katelyn and I will have Peter look at it - sounds like a defect that was not tested for - probably quite a quick fix I would think
