I have a spread sheet with data for Vertical Alignment of PI, is there a table I can import the data to?
with the great RPS command " edit alignment". Using this command you will just make a dummy vertical alignment. Pop open the “edit alignment” command and select the alignment you want to modify. This will have a pop up window that looks like an Excel sheet. click on the bottom of that says Vertical. There you can delete the old vertical and do a copy and paste from your spreadsheet. Click save and done. Verify in TBC that your vertical has been updated and looks like the data set you enter and done,
Wow!! That’s awesome! Thank you for taking time to show me that
