In this video we read in a PDF File of Sections to TBC, set the cross section data up for conversion to 3D, create an alignment against which we will reference and convert the cross sections and then flip the sections to 3D. Once completed we will make surfaces for Existing and Proposed and then make a corridor to review the sections and Cuts / Fills on the job. We then run a Corridor Earthwork Report and an Earthwork Report for comparison. There are a couple of minor fixes to apply to the sections after 3D conversion which we do with the Nudge Command.’
28 minutes soup to nuts and you have two volumes that you can compare to check against each other.
Hope this helps
Video shows you how
