I have a .dwg file that I imported that has a layer containing a “Shell3D” object. Is there a way to create a surface in TBC using that Shell3d object?
Hey James,
Have you tried using the Explode IFC Shell TML? This should convert the shell into usable data that you could then use to build your surface.
Worked like a charm. Really appreciate it.
