Compute Lot Setback
- The Compute Lot Setback command is part of the RPS Tool Shed Toolbox.
- The command is located on the Tool Shed macros menu ribbon.
- The command is located in the Subdivision menu group.
Computes the optimal location for a pad on a lot using required minimum setbacks from frontage and side lot lines. One lot side can also be defined as an edge frontage.
The following video shows how to utilize the Compute Lot Setback command:
The Compute Lot Setback command dialog looks as follows:
Setback line layer:
This drop-down menu allows the user to choose which layer the setbacks are drawn on.
Front:
This dialog box allows the user to define the setback distance from the front of the lot. The front of the lot is defined by the user’s selection at the end of the command.
Left:
This dialog box allows the user to define the setback distance from the left side of the lot. The left side of the lot is defined when the user selects the front of the lot at the end of the command.
Right:
This dialog box allows the user to define the setback distance from the right side of the lot. The right side of the lot is defined when the user selects the front of the lot at the end of the command.
Back:
This dialog box allows the user to define the setback distance from the back of the lot. The back of the lot is defined when the user selects the front of the lot at the end of the command.
Side (Frontage):
This dialog box allows the user to define the setback distance for a side frontage, a common example being a secondary street. In order for this to function properly, the side frontage setback must be less than the front setback, and there must be an arc on the lot boundary, as shown below:
Because this lot boundary includes an arc, the user may use the Side (Frontage) dialog to define the setback distance on the other side of the arc.
Draw Pad:
This toggle allows the user to choose whether or not a pad is drawn. A pad is an additional rectangle within the lot setback.
Width:
This dialog box allows the user to define a width value for the sides of the rectangle that are parallel to the setback.
Depth:
This dialog box allows the user to define a depth value for the sides of the rectangle that are perpendicular to the setback.
Name:
This dialog box will define the pad’s Name.
Pad Layer:
This drop-down menu allows the user to choose which layer the pad is drawn on.
Select lot boundary lines/Pick lot line:
This drop-down menu allows the user to build setbacks for an individual lot boundary or multiple lot boundaries together.
Boundary lines:
This dialog box allows the user to select multiple lot boundaries at once. The “Options” button will give the user quick access to multiple selection tools. These boundaries must be closed.
Pick Lot:
This dialog box will allow the user to define the front of a selected boundary and draw the setbacks. The user should click near the front of the lot when selecting the boundary, as this click defines the front of the lot.
Reference Line:
This dialog box will allow the user to define the front of an individual boundary and draw the setbacks. The user should click near the front of the lot when selecting the boundary, as this click defines the front of the lot.
This boundary must be closed.
Pad placement
Auto:
This toggle allows the user to enable or disable auto placement of the user-defined pad. This will cause the pad to be drawn simultaneously with the setbacks. When enabled, the pad will be drawn from the midpoint of the front setback line. However, when working with trapezoid-shaped lots, the user may define the pad orientation by where they select the lot line on the front side of the lot.
- Clicking the front lot line near the center of the line will rotate the pad to the average of the orientations of the left and right side lot lines.
- Clicking the front lot line near the right-hand side will orient the pad parallel to the right side lot line.
- Clicking the front lot line near the left-hand side will orient the pad parallel to the left side lot line.
Pad direction:
This dialog box allows the user to define an orientation for the pad. This option is only enabled when Auto placement is disabled.
Pad location:
This dialog box will allow the user to define the location for the midpoint of the pad width at which the pad will be drawn. This option is only enabled when Auto placement is disabled.
HEADER BAR COMMANDS
The following commands are enabled in the header of the RPS Compute Lot Setback command:
- RPS Help
- RPS Settings
- Takeoff Lines
- Smart Edit
- Adjust Linestring Elevation
- Track Region Outline
- Adjust Area
- Measure Distance
- Create Linear Dimensions
- Label Polygons
- Create Polygon Label Table
- Leader Lines
APPLY BUTTON
When you tap Apply, the lot setbacks and pad are computed and placed, and the command will prepare itself for another selection set and another process execution. If you do not want to make a second selection and repeat the process, tap Close to finish the process.
CLOSE BUTTON
The following videos show the use of the Compute Lot Setback command in a workflow context:
If you would like to provide feedback on the use of the Compute Lot Setback command or to request enhancements or improvements to the command, please click Reply below.
