Command Registration Error
I installed “Combine Surface” on RPS site, using the TML Status. It showed that I did not have this “Combine Surface” loaded. So, I loaded to command. Every since I’ve done that I get this error message that pops up every time I start TBC? It is like I have two of the commands installed?
Any suggestions as to why?
Thanks
We were about to release version 4.0 and I think this change sneaked out. Open File Explorer and navigate to C:\ProgramData\Trimble\MacroCommands\RockpileSolutions. Find the file CombineSurfaces.pydll and delete it, that should fix the problem. You may have to delete the file RockpileSolutions.dict in the same folder
That did the trick Peter. thank you.
