Does anyone else find the command pane overkill? There is a lot of good info here but I don’t use it.
I would prefer a simple command bar that I could hover or dock or attached to the ribbon or quick access tool bar and simply you type in characters and pick from the sorted list. Maybe a quick toggle for recent commands. The way the command pane cascades and takes over the screen is annoying and overkill especially if you are just using this as a quick search.
Something very short and sweet that you could dock on the quick ribbon to quick activate a command.
Maybe this could be a quick TML? @alan.sharp
