Is there a way to change the color of the text information while using the explore object command? When using the command to check a linestring, while utilizing a “dimmed” georeferenced pdf, it is nearly impossible to see the information. Thanks in advance.
Support>Options>Cursor color. You can change the text size and font under “Gridline and scalebar labels”
Thank ya kindly sir!
