We are often given bore hole locations in Lat/Long. Is there any easy way in TBC to covert these locations to Northing and Easting.
If they are Lat Long values you should be able to import them as a CSV file with a Lat Long file format definition (import format script definition) and then when imported to a project where there is a Coordinate System or Site Calibration defined they should get a computed NEZ value automatically. Once you have the NEZ points you can use them to create Boreholes at those locations.
Call me if you need help
Works like a charm. Thanks Alan.
