Block Editor Use Case
Today i was elevating lines with spot elevations using Adjust Linestring Elevation in Spot Mode. The elevation labels all had a block around them called Football - an American Football shaped oval that got in the way of fast elevating of the lines
To remove the ovals I just opened one of them in the Block Edit View available from the right click menu and deleted the oval - editing one instance changes all instances in the project.
Now i had clean text to work with
Block Edit View is really handy for this type of thing - doing this is “safer” than selecting all Blocks and deleting them becUse with that approach you cannot guarantee that you are not delting something useful by mistake.
