Append Linestring Vertical
I have run into this quite a bit especially with the vertical design sometimes being finicky on alignments (although it has gotten a lot better):
You can manually do this but it is a pain and you have to be very careful to get things to match up.
TML Prompts:
• Linestring to apply change to
• Vertical alignment to apply
• Starting Station of vertical alignment
