ADA Ramp Designer Command
- The ADA Ramp Designer command is part of the RPS Modeling Toolbox.
- The command is located in the Corridor menu group.
Elevates 2D ADA ramp linework to 3D using Min / Max design slope specifications. Labels lines with elevation and slope values for checking purposes. The command handles both single- and dual-ramp scenarios.
COMMAND HISTORY
v1 release with 2025.2 Release of RPS Command Library on March 10 2025.
The following video shows how to utilize the ADA Ramp Design command:
The ADA Ramp Design command dialog looks as follows:
Single or Dual Ramp Selection:
Select whether you are elevating linework for a single or dual ADA Ramp configuration.
Scale: XX.X - Change Plot Scale
The labels that are created to display the elevation and slope values for the elevated lines will typically be drawn in Sheet Units, i.e., if the Plot Scale is 50 and the Text Height is 0.08 Sheet Units, then the text will be 4.0’ high on the drawing once the linework has been elevated. You may need to change the current displayed Plot Scale to a different value in order to get the correct text sizing, i.e., change the Plot Scale to 10 to get a text height of 0.8’ on the drawing.
Click the Change Plot Scale button to change the value that is currently displayed to the left of the button.
Command Process and Calculation Method:
The elevation process requires that you select an already elevated curb line, one or two pairs of 2D ramp lines (the left and right edges of the ramp(s)), and the 2D landing pad of the ADA ramp configuration.
The command then elevates the ends of the ramp lines to the curb elevation and utilizes the settings defined in RPS Settings (see below) to determine the optimum slopes of the ramp lines and the associated elevations for the ramp line ends and the landing pad corners.
The calculation method starts with the ramp line that has the lowest elevation at the curb.
The command then applies the “Ideal Ramp Slope” parameter from RPS Settings to determine the elevation of the other end of the ramp line and the elevation of the landing pad.
The elevations of the other corners of the landing pad are then determined using the Ideal Landing Pad Slope from RPS Settings. This then determines the elevations for the 3 other Ramp lines to complete the computation.
If any of the ramp lines or the landing pad fail to fall within the Min / Max Ramp Slope or Min / Max Landing Pad Slope ranges, the elevations are adjusted up or down until all slopes fall within the defined criteria.
The lines are then labeled using a Text Style and Layer defined by RPS Settings.
RPS Settings - ADA Ramp Settings
The RPS Settings for the ADA Ramp Designer command look as follows:
Ramp Slope Settings:
The ADA Ramps of a sidewalk at an intersection crossing have a Minimum Slope %, a Maximum Slope %, and an Ideal Slope % that falls somewhere between the Min and Max values. These three values are defined here in RPS Settings. The Ideal Slope is used as a starting value for a ramp calculation and, after all ramps are computed, can be adjusted up or down automatically such that all ramp lines fall within the Min / Max slope definitions.
Landing Pad Settings:
The ADA Landing Pad (at the top of the ADA Ramps) of a sidewalk at an intersection crossing has a Minimum Slope %, a Maximum Slope %, and an Ideal Slope % that falls somewhere between the Min and Max values. These three values are defined here in RPS Settings. The Ideal Slope is used as a starting value for the ramp landing pad calculation and, after all ramps and the landing pad are computed, can be adjusted up or down automatically such that the ramp landing pad lines fall within the Min / Max slope definitions.
Layer:
Select the layer onto which you want to place the slope annotations that are created by the command on completion of the calculations.
Text Style:
Select the Text Style that you wish to use for the labels that are created by the command on completion of the calculations.
Select curb line:
Select the 3D curb line for the ADA Ramp to tie into. The line needs to already be elevated.
Select Ramp Pair 1: (single and dual ramp configurations)
Select the first ramp’s edge lines. These should be a pair of single 2D lines.
Select Ramp Pair 2: (dual ramp configurations only)
For dual-ramp configurations, select the second ramp’s edge lines. These should be a pair of single 2D lines.
Select Pad: (single and dual ramp configurations)
Select the ramp landing pad polygon. This should be a single closed line that has no elevation. On selection of the landing pad, the computations happen automatically, and the text labels for the ramp lines and landing pad will be displayed.
Results pane:
The command will display any results, passes, or failure information in the Results pane of the command.
COMMAND TIPS
The Command Tips area of the command provides access to Help (this document and video), as well as any other information that may be useful to know while running the command.
HEADER BAR COMMANDS
In the Header Bar of the command, you will find quick-access icons to RPS Smart Suite key commands and other commands that may be useful to you while running this command. These buttons will either launch the selected command or toggle to that command if it is already running. Header Bar commands associated with this command include:
- Help
- RPS Settings
- PDF Manager
- Smart Draw
- Smart Edit
- Smart Elevate
- Smart Model
- Offset Line
- Smart Copy
For example, once the main ramp lines have been elevated, you can use the Smart Edit command in Intersect mode to elevate the other ramp lines to the lines that have already been elevated using this command.
NEW BUTTON
If you wish to restart the process without executing the current selection, click New. This abandons the current selection process and starts over.
SWITCH COMMAND BUTTON
The ADA Ramp Designer command is a part of RPS Smart Suite. All Smart Suite commands have the Switch Command vs. normal Close command button. When you click on Switch Cmd, you can select Close to close this command, Close All to close all running commands, or select another command that is displayed in the list and is already running. You can also invoke the Switch Cmd list next to your current cursor location by pressing the ESC key on your keyboard.
The following videos show the use of the ADA Ramp Design command in a workflow context:
If you would like to provide feedback on the use of the ADA Ramp Design command or to request enhancements or improvements to the command, please click Reply below.
