Works Manger/Works OS training
Thanks Pat. Nothing like getting advise from someone who already has experience. What are the most common issues you have with the internet base stations and how often do they occur?
Very minimal. You just need to make sure everyone is using the correct base but everything has been fairly solid. I think in the 3~4ish years we have been using this we have had 3 hours of time where we couldn’t connect.
I name ours with a standard prefix and name so for instance our base at our office is SVT5-Candia That way our operators and field techs know where they are roughly located. You will also need to make sure you have decent cell coverage in your area. Not every project may benefit from this but it will cut down on a lot of setup and coordinating.
So far the two we have setup are in areas with good cell coverage. We will keep that in mind if we expand. Thanks for your help.
I’ve never heard of a Trimble Access base. Was it less expensive than an 855? I’m assuming it doesn’t have an internal radio. Looks cool.
https://www.trimble.com/Real-Time-Networks/Trimble-Alloy.aspx
We went with this because we have partnered with a VRS provider and this is what they recommended. This is the latest and greatest for base station technology, tracking all constellations and utilizing the maxwell 7 chip and Propoint engine.
Our base station network is made up of 2 Alloys, 3 NetR9s and 4 SPS855s.
Pat,
We have been running two of these base stations now for a couple of years (man time flies). One is directly hooked to an ethernet cable at our office and the other is using a sim card. The one at our office has worked fine but the other seems to vary through the day with cell usage. It is along a major hwy with plenty of cell towers around. Do you find the external antennae needs to be perfectly positioned facing a tower? Have you used any type of cell boosters? Any problems more from the signal on the equiment? I would appreciate any insights you may have.
2 years does fly.
-Starlink could be a good choice.
-https://rtkmobile.com/ - Allows for all 3 major mobile providers incase the area has questionable service.
We use these for our hotspots with external antenna to increase reception.
https://www.amazon.com/Cradlepoint-600Mbps-NetCloud-Essentials-Support/dp/B07FYY37HB/ref=sr_1_9?hvadid=557589221219&hvdev=c&hvlocphy=9002296&hvnetw=g&hvqmt=e&hvrand=13204496680044854772&hvtargid=kwd-6904419753&hydadcr=18001_13447350&keywords=cradlepoint&qid=1696965416&sr=8-9&ufe=app_do%3Aamzn1.fos.ac578592-0362-4e0a-958c-0f2dd61d30d4
We have had pretty good luck. You may want see if there is any data saving settings or influence by peak hour throttling.
The R780 directly supports a SIM now too. This could be a good option to test. They don’t however, support Verizon.
We are considering setting up our own base network. We have had what appears to be latency problems when running machines on a repeater within 5 miles of an internet base. Rovers seem to function normally, but the machines seem to be a second or two behind. Any thoughts on how to improve this setup? It’s tough to justify adding bases when the setup you have doesn’t seem to live up to expectations…
I have 2 Starlink units now and they work fantastic.
Also, Starlink just introduced the roam with 50GB/ month for 50. This should be more than adequate for base corrections and some minor misc.
I know this is about 4 years old but im running 1 Internet base from my office on verizon network and have had .013 HZ and VT precision on high end as far as almost 25 radialmiles from it while pulling 36 +/- 1or2 Sats on both my Dozers and rovers on that site while also having 3 machines and multiple rovers operating off same base 5-15miles from that base… I recently had a Komatsu with its base Topcon set up running off a server I had added to my 1 internet base while runnin a d2 w/earthworks off same base neck and neck and both ran .004 HZ/VT.. it shows how far the tech has come in the 4 yrs..
in addition to my last comment, i failed to mention i had a weird change in elevation (roughly 0.2+/-) EVERY day staring around 3:45pm (oddly enough never happened if i was on site) to fix the issue when you set up an internet base use a STATIC IP whether it be connected via WiFi or 4g/5g. networks. you can connect a Komotsu Machine using its stock GPS to you IBSS only with it having a STATIC IP anyways, but that’s how i ended up with the close to UTS precision
