Today I had a question about “Points Being Invisible” in the TBC Graphics. The Points were listed in project Explorer, we could make a surface out of the points and see the triangles, but we could not get the points to show up. The root of the problem was this …
In the View Filter Manager, at the base of the View Filter Dialog area, there are some additional settings. One of those settings is called “Show feature symbol only”. If this is enabled, and the points do not have any associated Feature Symbols then the points will be invisible as encountered by the user above. Simply un-check this setting to make your points visible again.
This short video shows you how
