TBC Winter Training Series
TBC Winter Training Series - from Rockpile Solutions
The New Year is here, and so is brand new live training from Rockpile!
Join us via Absorb & GoToTraining for live, online training beginning this January. Check out the schedule and details below!
Register Now
All Season Passes Include All Live Training
Need a season pass?
Season Pass - All Disciplines $895
Season Pass - Single Discipline $695
Season Pass - TBC Fundamentals $350
BUY AT ROCKPILE
BUY DIRECT FROM MYROCKPILE LIBRARY
Large group? Inquire about corporate options.
New Year - New Deal: RPS All Tools, Season Pass - All Disciplines, & Technical Support Agreement - $2195
Single Discipline Combo: RPS All Tools, Season Pass - Single Discipline, & Technical Support Agreement - $1980
Schedule
Wednesdays from 10 AM - 12 PM Mountain
Jan 11 - Takeoff Data Prep Methodology
Alan Sharp
  • Main steps to complete a takeoff
  • Key commands for each step
  • Google Earth Coordinate
Jan 18 - Updates to Vertical Design & Rule Functionality
Shane Odenbach
  • Global Vertical Design
  • Updates and Changes to Vertical Design
  • Rules and how they function
Jan 25 - Takeoff Calculation Methodology
Alan Sharp
  • Cateogorization and Site Improvements
  • Use of 2d vs 3d lines - How to use them properly
Feb 1 - Vertical Design - Best Use Cases
Shane Odenbach
  • Practical Applications of Vertical Design
  • Turnout/valley gutters
  • Cul de Sacs
  • preping linework
Feb 8 - Surface & Volume Manager
Alan Sharp
  • Advanced Surface Modeling and Volume Calculations
  • How to create surfaces
  • how to manage boundaries
  • calculating volumes
  • Annotating Drawings
  • producing deliverables
Feb 15 - Data Prep Commands for Elevating Data
Shane Odenbach
  • How to choose between commands
  • Side Slope
  • Multi-Offset Lines
  • Vertical Design
  • Adjust Linestring Elevation
  • Elevate commands Lines/Pads/Contours
Feb 22 - Utility Takeoff
Alan Sharp
  • Details TBD
Mar 1 - Converting a Takeoff to a Construction Model
Shane Odenbach
  • Moving from Takeoff to Contruction
  • Accuracy of PDF vs CAD
  • Rough Grade vs Finish Grade
  • Using Alan’s Takeoff Model from January Classes
Mar 8 - Using AutoCAD with TBC & Prepping Data for TBC
Alan Sharp
  • Autocad Commands for Making data available downstream in TBC
  • Civil 3d object that are exportable through XML
  • How to create a dwg file from Civil3D without aec object ref
  • making good 2d and 3d linework from Civil3D
Mar 15 - Data Prep: Slopes, Ditches, & Edge Cases
Shane Odenbach
  • Fixing Issues in slopes/Parabolic ditches or slopes
  • dealing with ripples and steps in slopes
  • building Parabolic ditches or slopes
  • barnroof slopes
  • override segment length
  • contraining intersections
  • elevating curb with adjust linestring elevation
Mar 22 - QA/QC of Construction Models
Alan Sharp
  • QA/QC of Modeling process
  • corridor as-built report
  • QA Lines
  • QA methods for Models
  • Random verification vs cross-sections
Mar 29 - Auto Pad
Shane Odenbach
  • To be Deterimined
  • Elevating Pad Areas and Steps/Slopes
Apr 5 - QA/QC of As-Built Models
Alan Sharp
  • QA/QC for As-builts
  • Reporting for structures
  • Reporting for Road Surfaces
  • Reporting for Sites
  • as-staked points vs surfaces
  • QA point clouds vs ground control or surfaces
Apr 12 - Using Microstation with TBC
Shane Odenbach
  • preping Microstation data for TBC
  • Exporting Alignments and Surfaces from Geopak
  • Exporting 2d and 3d lines from Open Roads
  • Working with DGN Files
Register Now
Need a season pass?
BUY AT ROCKPILE
