TBC Mini Class - Cut Fill Maps for Sites & Roads
Cut Fill Maps for Sites & Roads - Purchase Now
Class Date: April 21st 2021
Class Times: 10:00am to 12:00pm MST (GMT -7)
Class Venue: Online Training
Class Objective
The class objective is to teach you how to run volumes and produce great looking Cut Fill reports and outputs using Trimble Business Center.
Class Content
The class will cover:
  • Computing surface to surface volumes
  • Building Isopach surfaces
  • Defining an Isopach and how it is different to a Cut Fill Map
  • How to create a Cut Fill Map for a site project
  • How to create a cut fill map for a road project
  • Understanding the dynamic nature of a cut fill map and optimizing for performance
  • How to create and apply a preferred Cut Fill Map color scheme
  • How to edit and adjust a Cut Fill Map
  • How to create a Cut Fill Map legend
  • Tweaking the display properties to create great looking outputs
  • Adding contours to a Cut Fill Map
  • Querying and reporting a Cut Fill Map
  • How to create a great single sheet layout for a Cut Fill Map and Print to PDF
  • How to create a great multi sheet layout for a Cut Fill Map and Print to PDF
  • Adding 3D views and volume reports to a Cut Fill Map printout
$75
2 Hour Mini Class
$395
Mini Season Pass for all 12 mini classes
(SAVE BIG!)
Snag a Mini Pass
Subscriptions run for 12 months
View Next Class: Using the Sideslope & Slope Designer Commands
