TBC v5.8 Menu Ribbon
Below is a new RPS Menu Ribbon for TBC v5.80 (Version 5.80G).
The menu configuration controls three elements of the TBC User Interface
- Quick Access Toolbar
- Menu Ribbons and Menu Ribbon visibility
- Custom Toolbars and Custom Toolbar Visibility
To load a menu ribbon .bin file, go to the Support menu, run the Customize Ribbon command, select Import and browse for the downloaded .bin file (download link below).
To customize which menu ribbons are displayed at any time, go to the Support menu, run the Set Ribbon Tabs command and turn On / Off the Menus that you want to display.
You may also want to go to the Tool Shed menu and select Menu Manager and then do the following
- Select Light / Dark Mode
- Click Reset RPS menus
- Click Refresh icons
This will ensure that you are running with all of the latest menus and icons for RPS commands.
Last Updated: July 10 2023
This menu is the v5.8 equivalent of the new menu created for v5.90 of TBC - It has the commands that are new to 5.9 removed and the original RPS commands vs those that were renamed in v5.90.
Download this file and store it in a backup folder in your MyDocuments folder e.g. \TBC Master\Menus
v5.8I Menu.bin (5.8 MB)
Here are the Keyboard Shortcuts associated with this menu setup - save this in the same folder as the menus and print it out as a reference if needed.
Command Shortcuts v5.8C.xlsx (20.5 KB)
